2D PDF | .PDF | n/a | R | | Read wireframe and text only. To Write, use File-Print and “Print to PDF”. |
Dassault 3D Experience | .3DXML | R2024x | R | R | Catia V5/V6 Read license required |
3D PDF | .PDF | n/a | W | W | Write 3D PDF – all entities, levels, toolpaths, stock models. The 3D result is not viewable in a browser or hand-held device. We recommend the free Adode Reader. |
3D Mfg. Format | .3MF | n/a | RW | W | Imports meshes. Exports Solids and Surfaces as meshes |
ACIS | .SAB, .SAT | 2023.1 | RW | RW | |
Additive Mfg. | .AMF | n/a | RW | W | Imports meshes. Exports Solids and Surfaces as meshes |
Alibre Design | .AD_PRT, .AD_SMP | V24 | R | R | |
Autocad | .DWG, .DXF | 2024 | RW | RW | |
Autocad | .DWF, .DWFX | 2024 | R | n/a | |
Autodesk Inventor | .IPT, .IAM | 2024 | R | R | |
Autodesk Inventor | .IDW | 2024 | R | n/a | |
Catia V5 | .CATPart, CATProduct | V5-6R2023 (R33) | R | R | Catia V5/V6 Read license required |
IGES | .IGS | 5.3 | RW | W | Solids as surfaces. No views or drawing layouts. |
JT | .JT | 10.7 | R | R | Siemens 3D file format |
KeyCreator | .CKD | 2021 | R | R | Solids only. |
Parasolid | .X_T, .X_B, .XMT_TXT | 36 | RW | RW | |
Postscript | .AI, .EPS, .PS | 7,8* | R | n/a | |
ProE / Creo | .PRT, .ASM | Creo 10 | R | R | Creo Read Only license required – Also Uses Opens Files up to Wildfire 5 |
Raster 2 Vector | .JPG, .TIF, .BMP | n/a | R | n/a | |
Rhino | .3DM | 7 | R | n/a | |
Sketch Up | .skp | ? | R | n/a | Mesh Entities |
SolidEdge | .PAR, .PSM, .ASM | 2024 | R | R | This should support MBD but it is not currently – R-35745 |
SOLIDWORKS | .SLDDRW | 2024 | R | n/a | SOLIDWORKS must be installed |
SOLIDWORKS | .SLDPRT, .SLDASM | 2024 | R | R | Solids only. SOLIDWORKS required for Feature History or Sketches. |
SpaceClaim | .SCDOC | 2022 | R | R | Solids only |
STEP | .STP, .STEP | all | RW | RW | “Part 42” data/AP203, AP214, AP242, AP242E3 |
Stereolithography | .STL | 1 | RW | W | Imports meshes. Exports Solids and Surfaces as meshes. |
Unigraphics/NX | .PRT | 2306 Series | R | R | UG/NX Read Only license required |
VDA | .VDA | 2 | RW | W | Exports Solids as surfaces. |
Wavefront | .OBJ | n/a | RW | W | Imports meshes. Exports Solids and Surfaces as meshes; Wireframe as polylines |
